2000 6.0 NO START PROBLEM
Old Feb 12, 2008 | 11:48 AM
SMOKINJIMBO's Avatar
Default 2000 6.0 NO START PROBLEM
HEY EVERYONE ....COOL SITE ... I HAVE A TRUCK IN MY SHOP THAT WAS TOWED IN WITH NO START PROBLEM ...WE FIRST CHECKED FUEL PRESSURE ..LOOKED GOOD ..IT WANTS TO KICK A LITTLE BUT NO START ..REMOVED PLUGS AND CLEANED THEM AND THEY DO HAVE GOOD SPARK BUT THEY SMELLED GASSY AND WET AND BLACK BEFORE WE CLEANED THEM. CHANGED OUT THE CPS.. BUT STILL THE SAME ???? ANY ONE HAVE ANY IDEAS ?? THANKS IN ADVANCE TO ALL AND HAVE A GOOD ONE ... JIM []
Old Feb 12, 2008 | 3:10 PM
Friggen_Cobalt's Avatar
Default RE: 2000 6.0 NO START PROBLEM
What do you mean when you say it wants to kick a little? does it crank over and just not start or does it kind of stumble when you try to crank it? Are you sure it's not just a bad batt/connection or starter?
what kind oftruckis it exactly?
Old Feb 12, 2008 | 6:38 PM
THE TRUCK IS A GM 2500HD 4X4 6.0 ENGINE ...WE PUT THE PLUGS BACK IN AND NOW IT STARTS FOR ABOUT 2-3 SECONDS AND SHUTS OFF ??? IT SEEMS THAT THERE IS SOMETHING WRONG WITH THE BCM ... THE SECURITY LIGHT COMES ON WHEN IT SHUTS OFF AND YOU TRY IT AGAIN AND IT DOES THE SAME THING ...THE GUY SAID HE DROVE IT A COUPLE HUNDRED MILES SHUT IT OFF AND WENT ICE FISHING AND WHEN HETRIED TO STARTTHIS IS WHAT IT DID TO HIM.... WE ASKED A FEW OTHER TECHIES AND THATS WHAT THEY THOUGHT WAS WRONG WITH IT TO ...BUT THE 2500 SNAP-ONTHAT WE HAVE WILL NOT TEST THE BCM, BUT THEY TOLD ME THAT THAT A TECH 2 SCANNER WILL .....????? IS THEREANOTHER WAY OTHER THAN THE TECH 2 SCANNER THAT WILL DO THE JOB OR NOT ???? THANKS IN ADVANCE ....JIM
Old Feb 13, 2008 | 5:53 PM
have you tried testing the ICM(ignition control module)? How old is the snap-on scanner? It should be able to test it.
If you really think the bcm or pcm might be bad it might not be a bad idea to pull up a pin-chart on it and test some of the respective pins.
[/align]
Old Feb 14, 2008 | 1:38 PM
IM GETTING A P1626 CODE ANTI-THEFT SYSTEM FUEL ENABLE CIRCUT..???DO I NEED A NEW BCM ???
jstreet
Feb 18, 2012 7:14 AM
bracca
Jul 12, 2009 6:14 PM
pyrofytr
Jul 10, 2006 8:38 PM
