2000 silverado wont start
Old Mar 28, 2011 | 11:31 AM
srwhite928's Avatar
Default 2000 silverado wont start
I have a 2000 chevy silverado 1500 z71 5.3L 4x4 and yesterday I went to start the engine and it started cranking and I relized I forgot something inside, so I took the key out but the engine kept cranking with no key in the ignition and the engine wasn't starting. I had to unplug the battery to get the starter to stop cranking over. And now when I turn the key nothing happens at all. Had the battery and starter tested and they both work, I replaced the ignition switch and still nothing, replaced the cylinder key lock and still won't start. Anyone have suggestion as to what it might be wrong?
Old Mar 28, 2011 | 11:54 AM
EinST's Avatar
Welcome to the forum. Do you hear any sound at all, not even a little relay click? It sounds like the Starter Motor relay in the underhood fuse block may be shorted out but check the following as well:
10A Crank fuse in fuse block
Park Neutral Position Switch or Clutch Pedal Position Switch, depending on the transmission
40A IGN A fuse in underhood fuse block
sleepingciv
Jul 25, 2020 1:03 PM
Igor_Kiforishin
Dec 10, 2014 3:34 PM
Funpack
Mar 10, 2011 11:17 AM
bounty hunter
Oct 18, 2010 5:00 PM
jeffellis
Oct 11, 2010 11:19 AM
