2001 tahoe check oil level
Old May 3, 2006 | 2:05 AM
alpysv650's Avatar
Default 2001 tahoe check oil level
hey everyone...
just got a 2001 chevy tahoe even though i had the oil changed as soon as i bought it and the oil level shows %75 but the check oil light came on
i am pretty sure its not leaking..any ideas???
thanx
Old May 3, 2006 | 1:14 PM
SLJ2137694's Avatar
Default RE: 2001 tahoe check oil level
If you are within the operating range on the fluid level indicator and the check oil level light came on, you may have a problem with the oil level indicator electrical system. I noticed you listed your oil level as a percentage, are you confusing the oil life reading with oil level?
Old Oct 12, 2009 | 10:49 PM
blownmax's Avatar
Default I have a similar problem on a 07 silverado
when I turn on the ignition the dic flashes check oil light.the oil level was fine . right at the full mark. I've removed the oil sensor cleaned and checked for anything that may appear damaged but it seemed fine. then after beng unpluged and the battery being disconnected it didn't happen for a week or so then it started doing it agian. Is there anyway I can test the sensor to see if it bad. I'm not willing enough to spend 50 plus if it is still good.
some one please help with this problem. its driving me crazy.
Steelman512
Jun 8, 2023 2:51 PM
Snuggyworm
Sep 19, 2016 12:07 PM
exuL1B47
Oct 23, 2010 11:48 PM
BigShowJoe
Dec 16, 2009 6:52 PM
Toby T
Mar 14, 2008 5:16 PM
