2001 Tahoe Climate Control Recalibration
Old Feb 23, 2021 | 9:14 AM
Bill Devor's Avatar
Angry 2001 Tahoe Climate Control Recalibration
Hello All,
I recently ran my battery dead on my 2001 Tahoe w/ computer climate control. After charging the battery and starting the vehicle, my vents were cycling from defrost, to vents, to floor, non stop. I shut the truck off. When I restarted, it’s now “stopped” on vents. I can’t manually change it to defrost or floor and it won’t change on it’s own either.
I feel like it needs to be recalibrated? I have disconnected the negative battery cable for five minutes, restarted the truck and the same (stuck on vents).. I have pulled the HVAC fuse under the hood for 30+ seconds w/ no luck. Did I read someplace I need to pull the radio fuse also?
I would think disconnecting the battery would force a reset but…. Am I not following a procedure correctly?
I have been on YouTube and have seen how to recalibrate 2002 models with the digital temp. display but mine is just "AUTO". I will attach a picture of my controls. All the YouTube videos say to pull the HVAC/ECAS fuse. I only have Front Hvac or Rear Hvac fuses (no ECAS).
Blower and temp work fine.
Thanks for any help.
Old Oct 15, 2021 | 11:24 PM
2002turbokon's Avatar
Originally Posted by Bill Devor
Hello All,
did you ever find a fix to this problem? mine blows out of the front facing vents only and can't find a way to rest it..
Old Nov 14, 2021 | 4:24 AM
raehzrh's Avatar
Speed Test
Stormyj
2014 - 2018 (GMT-K2)
18
Jun 13, 2024 6:07 PM
Tyger255
Mar 10, 2018 4:23 PM
esokolowski
Feb 2, 2014 7:13 PM
ryan4237
Oct 8, 2011 2:23 AM
tomnz6668
Jul 9, 2010 9:59 PM
