2002 impala temp question
My 2002 6 cylinder impala started running hot. I took it to mechanic and he installed a new temp control switch. It used to run about one hash mark UNDER the half way mark. When it ran hot I turned on heater high and that kept it at the half way mark at traffic lights
on 80 degree days. At 60mph it ran about one hash mark below halfway. The fans come on but it has to get up to about 220 degrees and I'm worried about blowing a hard gasket if it gets too hot.
Where is the temp gauge supposed to run at. ? HALF WAY?......BELOW HALF WAY?
What would be considered the highest degree of temp I can run at without blowing a head gasket?
Thanks Guys
Patrick
Skagit County, Washington
Thanks Guys
Patrick
It should run with what the thermostat is set at, ex. 180, with a 300 deg gauge, 2/3 (ish). I'd ask how long has it been since the system was flushed, and are you using coolent instead of just water?
Thanks for your Help
Patrick
