2004 Cavalier clutch issue
Old Jun 28, 2020 | 7:45 AM
tim_james2's Avatar
Default 2004 Cavalier clutch issue
Hello , I just received a 2004 Cavalier that the clutch is not working. I was told by a guy that it needs to be bled, but it is easier to simply replace the clutch master slave cylinder rather than bleed the old one. I would like to know the location of the clutch master slave cylinder and hope that someone can provide information on replacement and maybe a picture of this item and location. That way I don't waste a bunch of time fumbling around under the hood.
Old Jun 28, 2020 | 12:05 PM
the slave is called the clutch actuator cylinder and its in the transmission next to the release bearing. you can release the hydraulic line without removing the trans but to replace the cylinder trans must come out.
Old Jun 28, 2020 | 1:35 PM
tim_james2's Avatar
I am replacing the Clutch Master Cylinder, it is not inside the transmission it hooks to the clutch pedal. I was asking for information and diagrams but believe that I have found everything and am almost complete.
Old Jun 28, 2020 | 2:28 PM
Originally Posted by tim_james2
Hello , but it is easier to simply replace the clutch master slave cylinder rather than bleed the old one.
hard for me to know when you combine the names.
Old Jun 28, 2020 | 2:34 PM
tim_james2's Avatar
I;m sorry that is what the name of the part is that I purchased from a parts store.
Old Jun 28, 2020 | 7:00 PM
the clutch master cylinder located on the firewall creates the pressure to move the slave cylinder located on or in the transmission.
master commands the slave hence the name.
Old Jun 29, 2020 | 3:23 AM
tim_james2's Avatar
Well it is back together and on the road again. Thanks for the help.
2004 cav
Aug 15, 2012 11:37 AM
spiderman1964
Apr 24, 2010 10:15 PM
63NovaSS
Apr 11, 2007 10:14 PM
