2004 Suburban Codes P0101 and P0300
Old Mar 21, 2015 | 8:25 AM
UM Rebel's Avatar
Default 2004 Suburban Codes P0101 and P0300
I have a problem with my 2004 Suburban I hope someone can help with. It runs really bad, no power, clatters and backfires will hardly go over 45. CEL is on and sometime flashing. Autozone read codes P0101 - Mass Air Flow (MAF) Circuit Range/Performance Problem
P0300 - Random misfire
Changed MAF with my Corvette. Corvette still runs fine (no codes). Suburban still runs bad. Checked cats temp front (300 degrees) , back (500 degrees). Checked fuel pressure at 45psi . When I blip throttle jumps to about 50. From what I've seen fuel pressure should be a little higher. Where do I go from here? What do y'all think is going on? Thanks for any help and advice. BTW is 2WD with 5.3l non Flex fuel engine.
Old Jan 15, 2016 | 10:40 PM
skycries57's Avatar
went through same on mine, cleaned maf sensor and went back to norm. same on my toyota sienna. could b bad coil or plugs. if its been a while since replacement on coils and plugs, its a cheap fix, betcha it will fix it, did mine and others i know of when these issues come up.
Old Jan 17, 2016 | 8:22 PM
cleveland63b's Avatar
your corvette probably has different calibrations I wouldn't count that as an accurate test for anything, I would also start with cleaning the MAF and see if it changes anything, do you have access to a scanner at all? Start with the p0101 it may be the same root cause for the p0300
UM Rebel
Jun 12, 2020 2:02 AM
4tofloor
Apr 18, 2015 8:57 AM
TURBOPOWERED68
Jan 27, 2012 1:04 PM
scrnchr
Jan 26, 2012 10:43 AM
nj85z28
Dec 29, 2011 1:35 PM
