2007 silverado classic PO304 misfire code
Old Mar 22, 2022 | 5:52 PM
Jassim's Avatar
Default 2007 silverado classic PO304 misfire code
Recently bought a 07 silverado 1500 classic 4x4 and just love this truck it has the 4.3 engine and now I am getting a misfire in cylinder 4 . also just had lifters replaced before all this began the mechanic cant seem to find the problem but loves to replace things and get my money . plugs , cables , distributor cap and rotor were replaced and coil pack . I get a check engine https://19216801.onl/ https://routerlogin.uno/ light on steady and after about 2 or 3 miles of a steady cruising speed it will start bogging down or slit hesitation and when I hit the gas it starts to sputter and then it eventually clears and speed starts going up fast please help
Old Mar 23, 2022 | 2:12 AM
oilcanhenry's Avatar
Originally Posted by Jassim
Recently bought a 07 silverado 1500 classic 4x4 and just love this truck it has the 4.3 engine and now I am getting a misfire in cylinder 4 . also just had lifters replaced before all this began the mechanic cant seem to find the problem but loves to replace things and get my money . plugs , cables , distributor cap and rotor were replaced and coil pack . I get a check engine light on steady and after about 2 or 3 miles of a steady cruising speed it will start bogging down or slit hesitation and when I hit the gas it starts to sputter and then it eventually clears and speed starts going up fast please help
Here are all the codes for a P0304 condition:
P0304 CHEVROLET code possible causes
  • Faulty spark plug 4
  • Clogged or faulty fuel injector 4
  • Faulty ignition coil 4
  • Fuel injector 4 harness is open or shorted
  • Fuel injector 4 circuit poor electrical connection
  • Ignition coil 4 harness is open or shorted
  • Ignition coil 4 circuit poor electrical connection
  • Insufficient cylinder 4 compression
  • Incorrect fuel pressure
  • Intake air leak
I hope this helps you out.
Dickie
Jul 15, 2021 7:36 AM
stracci236
Feb 27, 2021 7:02 AM
Chevyidaho
1988 - 1998 (GMT400)
Mar 4, 2018 8:19 PM
juspassinthru
Mar 8, 2011 5:16 PM
99Silverado
Jun 8, 2007 5:59 PM
