2007 Suburban HVAC problem
Old May 16, 2015 | 5:10 PM
amflyer1's Avatar
Default 2007 Suburban HVAC problem
Purchased a new climate control module for 2007-2011 dual zone model with rear control. After about 1-hour of running, all the ducts shut off blocking the air output and I can not control where the air comes out. Also makes a lot of wind noise as if you have the air on recirculate. After the car sets idle for a while, all is normal again. Rear control still functions through all this but the foot-ceiling control is backwards. ie. if you select foot outlet, the air comes out of the roof.
I have tried (2) control modules with the same results. I have tried the teach routine of pulling the fuses and turning the ignition key on but no change and I get no indication that any computer learning happened.
HELP!!!
Rich M
amflyer1
May 17, 2015 7:35 AM
Craig6
Oct 14, 2014 10:13 AM
jmichael1964
Jul 7, 2013 2:39 PM
Smokey79TA
Oct 4, 2010 2:38 PM
greggk
Apr 29, 2010 7:50 AM
