2008 2500 HD at 110,000
Old Mar 13, 2014 | 7:37 PM
Caprocker's Avatar
Default 2008 2500 HD at 110,000
I'm new here so be easy on me. I've tried to update my vehicle in my sig as much as I know. Here's my reason for coming to the source! I've turned over 110k in my rig and it's started doing some very un chevy things.
Leaks! All of which started at the same time. I've acquired a coolant leak from the back driver side area of the block. Right in the general vicinity of the back exhaust port on the exhaust manifold. It only leaks during cold weather! And it doesn't leak much..I did see that I've got busted manifold bolts on the front and back.
I also have leaks on the front transmission line connections. Those leaks have since stopped but I can see where they had leaked.
Lastly..my cruise control isn't working properly. Most times it won't engage at all unless I lift up on the brake pedal...
All of the leaks started after the low digit cold we had this year in December. I want to fix this stuff myself as much as possible! Any help from you guys would be much obliged!
Johnw
Old Mar 13, 2014 | 7:42 PM
Caprocker's Avatar
The truck is a 2500hd vortec 2wd
I am struggling to get my signature edited.. Sorry
cplnorton
Feb 11, 2014 8:21 AM
Mr. Bojangles
Jan 1, 2014 7:02 AM
