2008 Chevrolet Silverado 1500 5.3 Clock reset
Old Dec 9, 2019 | 9:55 AM
Martin1183's Avatar
Default 2008 Chevrolet Silverado 1500 5.3 Clock reset
Hey guys, so the last few weeks my clock started to reset to 12:00 every time I start the truck, the odd time it stays the same but for the most part it resets 90% of the time same with my Hvac resets to dual climate and at 23 Celsius, battery is 5 years old, last week my starter went I changed that out and works now,
any help would be appreciated , thank you
Old Dec 9, 2019 | 9:58 AM
Check your fuses. There is a power line to the radio that keeps the memory when turned off, that fuse is probably blown.
Old Dec 9, 2019 | 9:59 AM
Martin1183's Avatar
Is the fuse inside on the left side of the dash?
im assuming the fuse is for the hvac resetting as well?
Old Dec 9, 2019 | 4:25 PM
There are 2 fuse boxes in the truck. One under the hood and one inside. Not sure which fuse it would be on your year. I would also check the battery cables for corrosion and being loose at both ends.
raydar
Jan 20, 2023 10:46 PM
2kimin
Sep 17, 2017 5:01 PM
Chevyman06
Nov 14, 2015 4:45 PM
Myriam
Aug 5, 2014 9:04 PM
Ron Malinowski
May 29, 2014 11:03 PM
