2016 Silverado Oil Leak
Old Sep 5, 2018 | 1:35 PM
medina3's Avatar
Default 2016 Silverado Oil Leak
I have 2016 Silverado 1500 LT 4x4 with about 50k miles, I see oil leaking from an area by the bell housing. Has anyone else seen or experienced this?
Old Sep 5, 2018 | 1:39 PM
if its oil, not trans fluid...the most common leak source is the trans pan gasket. there are other possible sources...post a picture
Old Sep 10, 2018 | 11:14 AM
medina3's Avatar
Dealer confirmed oil is leaking, I saw it at the inspection hatch. Dealer called this morning & will be covered under powertrain warranty but because I have a lift kit it will cost me $300. Does that sound right?
Old Sep 10, 2018 | 4:41 PM
what part is leaking? if the lift kit interferes with part removal resulting in more labour time, your paying for the additional time.
Old Sep 11, 2018 | 10:48 AM
medina3's Avatar
said they had to replace the upper oil pan, no sure why the lift kit matters here.
