2018 2500HD 6.0 have any form of AFM?
Old Nov 11, 2024 | 5:00 PM
Mumbles907's Avatar
Default 2018 2500HD 6.0 have any form of AFM?
Looking to buy a 2018 2500HD with the 6.0, trying to avoid any form of AFM. Just curious if the 2018 with the 6.0 has AFM?
Old Nov 12, 2024 | 4:35 PM
Oldcat's Avatar
No. The 6.0 does not have AFM of any kind. That's the beauty of the 6.0. It does have variable camshaft timing but no cylinder deactivation which is what AFM is.
Old Nov 12, 2024 | 6:05 PM
Mumbles907's Avatar
Awesome! Are there any issues or things I can do to prevent issues with the VCT? Or issues in general besides keep up maintenance? Will be my fist Chevrolet
Old Dec 31, 2024 | 8:28 PM
Swan01's Avatar
No, this version of VVT is very simple. Just a Camshaft adjuster magnet, oil control valve, and the camshaft phaser. Oil changes with high quality oil will be key!
Old Dec 31, 2024 | 8:29 PM
Swan01's Avatar
[QUOTE=Swan01;510538]No, this version of VVT is very simple. Just a Camshaft adjuster magnet, oil control valve, and the camshaft phaser. Oil changes with high quality oil will be key! Use Mobil 1, make sure it says “Dexos1, generation 3” on the front for best quality and performance from that engine, they hate ****ty oil
Old Dec 31, 2024 | 9:48 PM
Mumbles907's Avatar
[QUOTE=Swan01;510539]
Should i be able to expect 200k miles or over before anything major?
Old Dec 31, 2024 | 10:04 PM
Swan01's Avatar
[QUOTE=Mumbles907;510541]
I will say this: as long as you keep up maintenance that thing will run probably close to 250k, maybe 300k before anything major engine related.
- Change oil with dexos gen 3 + Mobil 1 filter every 5000 miles, no longer unless you want sludge.
-change transmission fluid every 35,000 miles, fluid, filter, pan gasket
-change differential fluid every 50,000 miles
If you do all of that and just keep an eye out for any leaks (big thing on GM trucks) that will run forever. It may tick a little bit like mine does, it’s normal literally everyone of them does it so don’t worry. Obviously if it’s loud be worried but a quiet little tick that’s barely audible is fine. Main things are do the above maintenance schedule and repair and leaks right when they start, it’s a solid vehicle!
PNW NBS Z71
2014 - 2018 (GMT-K2)
Dec 5, 2020 6:25 PM
txndncowboy
2019+ Silverado (GMT-T1)
Oct 9, 2020 5:09 PM
IB Nolan
Newsletter Archive
May 21, 2018 4:12 PM
One1014
May 17, 2018 7:45 AM
