2018 Silverado Swap Steering Column?
Old May 5, 2020 | 10:32 AM
JT58.Bronc66's Avatar
Default 2018 Silverado Swap Steering Column?
I bought a 2018 Silverado Custom and it came with just the tilt steering. I wish that I obtained the telescoping steering, being on the tall side.
Is it possible to swap out the tilt steering column for telescoping? I went to GM Partsdirect.com and looked at the columns and there are two different ones available- tilt or telescoping. I also looked at all the parts that are associated with it that are different between the 2 columns. The only different parts are the column cover and a wiring harness. All of the other components seem to be the same, common to both. I can buy the column, cover and the wiring harness for a reasonable price.
Is it possible to swap one for the other? Is there a U Tube or instructions on how to remove the steering column? I assume all of the levers, wires, etc. need to be transferred over. I am very experienced and feel I could do it, if I had some sort of instructions. I searched on the Web for steering column removal and came up with nothing for this generation trucks..
Scott Eley
Feb 24, 2020 12:20 PM
Larrycarol
Oct 3, 2017 12:45 PM
jstonemo
Jun 3, 2016 4:11 PM
jaymoung
Dec 18, 2011 9:33 PM
bg1977
Feb 10, 2008 6:30 PM
