3 codes
3 codes
have a chevy 2005 express, stopped at store came back out and van wouldn't start, put new starter on, still nothing, i can start van by jumping solenoid, after i started it took it down road and check engine light is flashing, put tester on and have three codes po753, po758 and p2761 so besides not starting with key codes says transmission isn't shifting, have checked grounds and replaced neutral safety switch everything still the same, could use any help out there
This sounds like a power distribution or ground path issue. The codes you listed aren't just saying the transmission isn't shifting, they are saying there is Circuit problems with those shift solenoids. Those shouldn't prevent you from starting so there is another circuit problem for the starting system. So you are most likely missing power or a ground that feeds multiple items. It will take some electrical testing to see what you have and what you don't, to find out where the issue is.
If you are willing to try all of that just to see if it works, please try my online diagnostic service at www.dtcassist.com first. It's made for situations like this, and the cost is far less than the parts you are talking about replacing. We research the factory schematics and faults you have, then identify where the problem likely is, and how to test it to be sure. It's a lot simpler than it may sound once you have the right information.
Tashier
13
March 24th, 2012 3:48 PM
