305 head- 350 head
Old Nov 4, 2010 | 8:51 PM
NovaProject's Avatar
Default 305 head- 350 head
I was wondering if anyone can tell me if a cylinder head from a sbc 305 will work on a sbc 350. will it make a 327 or will the compression ratio be way off.
If somene could help that would be great.
Thanks
NovaProject
Old Nov 5, 2010 | 8:16 PM
rwilly's Avatar
Scroll down a little bit and read the thread on my engine swap questions. I swapped a 350 for a 305 and there was quite abit of information posted on swapping the heads. It is do-able, but not recommended. Good luck
Old Nov 6, 2010 | 10:50 AM
Thank you for the help. I will take that into conciduration for the build.
Thanks again.
Old Nov 6, 2010 | 12:35 PM
2wd-K5's Avatar
it will raise the compression but cut the power because 305 heads cant flow at all, u will end up with an engine that cant flow and the timeing will be waaaay retarded so it will be absolutely gutless
87caprice718
Jul 29, 2015 5:16 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
sally
Jul 29, 2008 7:38 AM
wazzan_88@hotmail.co
Nov 12, 2006 5:38 AM
