350 -> 383 rebuild
Old Sep 9, 2006 | 7:17 PM
KyleTaylor19's Avatar
Default 350 -> 383 rebuild
Would it be more cost effective to purchase a crate engine than to rebuild the 350 I have in my garage... I would like some moderate power for this project, nothing too crazy....
KYle
Old Sep 10, 2006 | 12:32 AM
kcb37's Avatar
Default RE: 350 -> 383 rebuild
A 383 stroker is a bored and stroked 350.
My question is what do you do with this pickup?
Do you need more power?
Your gas mileage will go down and if the 350 runs you don't need to change anything. But I do see how you feel, I like power too.
Old Sep 10, 2006 | 2:43 PM
The engine is going into a project car. I will post some pictures and info when it is complete. Hopefully within the month.
I found a "stroker 383 kit" for $700 on eBay that I am going to try out. I am used to working on BMWs and Mercedes so the use of cast parts scares me, but it seems commonplace in domestic engines.
I am really just looking for a mild increase in power, and probably about 10.2:1 compression... with a carb and losts of polishing of the head... and headers
This is a learning experience for me.
Old Sep 12, 2006 | 1:13 AM
BUY A NEW ONE!!!
Machining, and parts are way more expensive!
Old Sep 27, 2006 | 3:01 PM
uncle bill's Avatar
Originally, the 383 was a 350 block bored .030" oversize, a modified 400 small block crankshaft ( so the main journals would fit in a 350 block ) using 400 connecting rods and 350 pistons. With that, the 400 harmonic damper and flywheel was used and the assembly was balanced to get everything in sync. These days, You can buy aftermarket 383 specific crankshafts etc. A low budget approach is to get a Scat cast crank kit with a complete rotating assembly. The machine work cost on modifing a 400 crank etc., makes an aftermarket setup cheaper and better because the parts are new instead of reconditioned.
BGummer
Jun 4, 2011 9:47 PM
