350 Automatic Trans
Old Sep 14, 2014 | 12:46 AM
Doug_h's Avatar
Default 350 Automatic Trans
Hi Have transmission question. The transmission case socket has two pins for torque lock up. where do the two wires go to ? is one pin have to go to ground? The is transmission 350 GMC early 1980's . Is it important to wire it to the brake switch?
Old Sep 14, 2014 | 9:09 PM
silverado 1500 2001's Avatar
wow i'm learning from the question. two pins could mean computer + and -, or could be two + and ground is case, dunno sorry. i see if you google it some people have articles. you could check your volts while running to answer your question maybe. and yes brake switch seems important. you maybe can test it if it "seems to work" by feeling hose pressure, or with a test drive (perfect lock / mileage issues aside). trans have fluid circuits more complex than electric ones (ie, by check ball) also.
Old Sep 14, 2014 | 9:14 PM
did you read this ? Diagnosing GM Converter Lock-Up Problems
here's an interesting warning for solenoid it says: BE SURE TO OBSERVE PROPER POLARITY, if using a car battery.
donjuandejohnson
Jun 23, 2015 11:15 PM
ooCHICOoo
Jun 10, 2011 8:20 AM
ironclad
Aug 20, 2008 9:12 PM
jonathanMcd
Jan 30, 2008 11:20 AM
andregg1
Nov 1, 2006 8:49 PM
