350 caburated won't run long
Old Sep 24, 2010 | 2:33 PM
servermans's Avatar
Red face 350 caburated won't run long
Ok I have a 1975 camaro, Lt model. It has a 90's good wench crate 350 with and edelbrock 1407(750cfm manual choke).
The pump plunger broke and I replaced it myself and I decided while I had the top end off the carb I would replace the needle and seat assembly because it was looking old. This was the first time I've really worked on a working carb. Ok so I got it all back together and it ran ok so I took it for a cruise and got about 5blocks and it died. It now will run for around 15 to 40 seconds but it has to sit for a minute or 2 before it will start each time. Idk why it won't work but I'm guessing I did something wrong with the carb. Also when it broke down on the road my dumb friend started messing with the tuning on the carb so I'm guessing its way out of tune and idk how to tune it. It would be nice if someone could post a link to how to tune it. My cell phone is my only internet so it takes a long time to look things up for me. Well thanks for your time.
Old Sep 24, 2010 | 4:55 PM
servermans's Avatar
I also just saw that its leaking gas from (I'm mot sure the real name for the spots) around were the trottal rods go threw
Old Sep 24, 2010 | 7:43 PM
therewolf's Avatar
Hi servermans,
Welcome to the Chevy Forums.
It sounds like it is time for a new carburetor, or possibly a fuel system upgrade, depending upon your inclination.
You seem to be describing accelerator pump failure(not hooked up? collapsed?)
Idle mixture screws out of adjustment, AND a leaky throttle body. Not a favorable combo, maybe somebody here is an Edelbrock 4barrel fan who can shed some light on your predicament?
Old Sep 25, 2010 | 9:48 AM
servermans's Avatar
Sorry for the multi post last night I'm not sure how it happened. So I did a full rebuild myself last night and now its not leaking anymore and the acceleratorpump seems to work. Well now it still won't idle long.
Old Oct 1, 2010 | 3:15 PM
2wd-K5's Avatar
is your choke set up properly? sounds like the problem, when your car gets warm pop off the air cleaner and see if the choke flap is open on the primaries
Old Oct 14, 2010 | 11:42 PM
Rusty-454's Avatar
Check the float and needle and seat if they are stuck. sounds like nothing is holding the fuel back and just pouring in
sirocco110
13
Jul 24, 2016 2:55 PM
hakasaw
Jan 13, 2014 10:47 PM
k1500vzpbmf
Nov 29, 2012 4:37 AM
larryntripp
Oct 23, 2008 8:13 PM
brobaey
Aug 3, 2007 7:40 PM
