350 problem
Old Oct 7, 2010 | 4:42 PM
78mc355350's Avatar
Default 350 problem
i have a 78 monte carlo with a 350 just had it rebuilt it ran fine before just a little funky oil pressure and small tappin noise so come to find out someone else rebuilt it and put standard bearings with a 20 20 shaved crank but ne way so its rebuilt put it all back together with all new parts started it up and it doesnt run all that great if u put it into drive it will bogg down and die and spit a little gas out ive quadrouple checked timing put a new distributer in checked vaccum leaks even replaced the carb(running Edelbrock 1406 Performer 600 and msd Street Fire HEI Distributor) so i took all the vaccums off xcept the advance checked plugs they are blackened with carbon deposits i mean this motor has only ran for an hour or so not even driven wtf is going on please help oh and valves have been adjusted correctly too <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Oct 9, 2010 | 12:51 AM
2wd-K5's Avatar
if the plugs are sooty, that maens it is running too rich, just adjust the idle screws 1/8 turn and listen or smoothing out of the engine
Old Oct 11, 2010 | 9:54 AM
auldShaman's Avatar
Default go back to basics
when i can't find out what's wrong, i go back to basics, check the compression on all 8 plugs, cranking compression on a new engine should be about 100psi, then put a vacuum gauge on and start it up, you should see about 20 inches of vacuum and steady...if it's fluttering, there could be a tight valve or the timing chain could be off a tooth
5.0stang
Jun 16, 2022 7:46 AM
computerdude14
Jan 8, 2013 3:33 PM
shawnmid
Aug 4, 2010 1:19 AM
shawnmid
May 22, 2009 7:29 AM
