350 SBC Timing
350 SBC Timing
I'm needing to set the timing on our '79 C60 straight truck... However, there's a catch. I have no accurate timing marks!
It's got a pretty standard bone-stock smallblock 350 with HEI igniton, but the marks on the balancer have "slipped" (the balancer uses a rubber bushing to mount up to the crank, and it rotated a long time ago). I have all the equipment for conventional timing, but with those marks messed up it isn't going to do me much good.
What I was wondering is if anyone has any experience with setting ignition timing with a vacuum gauge? After doing a little research it seems that it's a very common practice for people who have engines that cannot be timed conventionally for whatever reason, and some even claim it does a better job than normal timing with a light. However, there's also just as many people who gripe and complain and say that the method is inaccurate. Any insights on this?
Basically the process is to disconnect the vacuum advance, set the engine at a nice idle, advance the timing to achieve maximum vacuum reading, then retard it back about 1 to 2 inches of vacuum.
Well, one big ?. Are you saying the line on the balancer is, gone, or the timing tab? It's keyed to the crank. If it is running, then you have it somewhat right. You should always disconnect the vacuum to the distributor when setting the advance. Mechanical advance should be around 30 deg at 3000 rpm. I always just used a match book to set .017" point gap at 700 rpm or so. With that said, yes you can set the timming with vacuum, however I don't suggest that since altitude will have a different effect on carburation.
Oh, a couple other things while on the subject...
1) Does ambient (weather) temperature have a major effect on setting timing?
2) Does changing the intake or exhaust systems screw up correctly set timing?
Just curious as the weather outside is pretty chilly these days, and we may or may not be changing the exhaust setup someday in the future.
