400 smallblock question
Old Sep 7, 2010 | 10:37 AM
scooby30909's Avatar
Default 400 smallblock question
Im building a 400smallblock for my streetstrip 84 Buick Regal. The 400 has been bored 60over. Im running 64cc chambered aluminum procomp heads that have been resurfaced twice not shaved(not sure how much was taken off). I want the motor to stay pump gas friendly while making as much compression as possible. Would flat top pistons give me too much compression for pump gas? Or would I need to go dished? And will this motor create too much heat to run hypereautic pistons. If I sprayed any nitrous to this motor it wouldnt be anymore than a 150shot. Thanks for any input...
Old Sep 7, 2010 | 12:31 PM
old dog's Avatar
Default 400
your pushing it with a .060 over bore flat tops with small chamber heads will prob push it over the edge for pump gas ,you better have the heads cced and have a machine shop compute how much compression you will have .i had a stock bore 400 with flat top,s and stock head's and it was just able to use pump gas .
Old Sep 7, 2010 | 2:29 PM
Thanks for the reply... Ill definately go with some dished pistons then... Do you think I would be fine with hypereautic pistons? I hate to spend money on forged if I dont need them...
Old Sep 7, 2010 | 2:39 PM
old dog's Avatar
Default 400
i guess i have never heard of those pistons ,but regular cast should be ok for a street pounder .do the heads have the steam holes drilled in them ?nitrous on that motor would not promote the life span on the head gaskets
Old Sep 7, 2010 | 9:03 PM
Hypereautic pistons are the better of cast pistons(stronger) but not as good(strong) as forged.Withoug running alot of nitrous I think hypereautic pistons will work fine with a 150shot... Thanks for your comments... really helped...
400Smallblocker
Aug 3, 2014 6:10 AM
DylanG
May 18, 2014 12:44 PM
