427 build speed demon question
Old Mar 21, 2010 | 2:07 PM
guessg's Avatar
Default 427 build speed demon question
Currently building a chevy 427 with 9:5-1 comp oval ports. It will have a Edel. rpm airgap intake, headers. Cam has 250 advertised with 245 at.50 and 540 total lift. 16 degrees inital timing with a total 36 at 2800 rpms. Msd billet distributor. Manual trans. I have a Speed Demon 750 with Vacuum secondaries and was told I needed speed demon 750 with mechanical secondaries. Is there a way to setup and use my current carb to work with this app. If so, what would be a good baseline setting for the carb( power valve, jets etc).On a tight budget
Old Mar 21, 2010 | 4:23 PM
maxxman04's Avatar
sounds like someone told you their opinion, not fact. vacuum secondaries is fine. just hook it up to vacuum source on manifold.
HotRodRick
Chevelle & El Camino
Mar 22, 2015 2:09 AM
HotRodRick
Feb 17, 2015 8:23 PM
