4L60E tranny questions
Old Mar 17, 2014 | 11:33 AM
ljwhite174's Avatar
Default 4L60E tranny questions
I have a 92 c1500 with the 4L60E auto bolted to the 350, the problem i am having is when in OD going around 65-70 mph the whole truck will shutter then stop and then do it again, it only does it around these speeds and only in OD, when in D it doesnt do it but seems the RPM are alot higher (almost 1k) then in OD, I checked trans fluid and color, consistancy, and level all check out good, not sure what the next step would be, thought of trying seafoam trans tune and then doing a filter and fluid change but have seen to many mixed reviews on it, i have also checked the u joints they are tight all mounting hardware in the rearend is tight, trans mounts are tight and in good shape, not sure where or what to check next
donbrearley
Jun 26, 2013 10:26 AM
abqgolfer
Aug 27, 2011 11:30 PM
nrenee918
Jan 15, 2010 8:50 AM
a_r_fowler
Dec 4, 2007 11:23 AM
LILSUTHERN
Sep 13, 2007 2:57 PM
