4l60e transmission problem
I have a 1998 chevy ck1500 with a 4.3l vortek and 4l60e trans. Driving to work one morning the trans acted like it popped into neutral, when I got below 50mph it went into third and stayed there. I could manually get second and reverse but no first or fourth. Also the check engine light went on. If I shut the truck off then restart it drives normal for a few hundred miles then it happens again. I checked the code and it came up "shift solenoid B electrical circuit". I replaced both A and B solenoids and it still does it every couple of hundred miles. took it to a trans shop and they think it might be the computer but not sure.
These are in the Valve Body, Right? did you do it yourself (the change ) or a shop. If a shop how much did it cost you? I'm having issues with mine but my Service manual says possible clog (I don't have any codes however). Just need a heads up on how hard it would be to take out the VB.....
flewster
July 28th, 2021 3:20 PM
abqgolfer
August 28th, 2011 12:30 AM
mygreenihc
August 30th, 2009 11:34 PM
oppelousas
July 25th, 2007 2:46 PM
