4l60e transmission problem
Old Dec 29, 2009 | 5:20 PM
Billytk's Avatar
Default 4l60e transmission problem
I have a 1998 chevy ck1500 with a 4.3l vortek and 4l60e trans. Driving to work one morning the trans acted like it popped into neutral, when I got below 50mph it went into third and stayed there. I could manually get second and reverse but no first or fourth. Also the check engine light went on. If I shut the truck off then restart it drives normal for a few hundred miles then it happens again. I checked the code and it came up "shift solenoid B electrical circuit". I replaced both A and B solenoids and it still does it every couple of hundred miles. took it to a trans shop and they think it might be the computer but not sure.
Old Dec 29, 2009 | 6:28 PM
gotstylez's Avatar
try to reset the computer..take the pos. off the battery and wait 30 mins or so.. and it'll reset it..see if it does it again
Old Dec 29, 2009 | 7:22 PM
Billytk's Avatar
I've done that. Still does it every 200 miles or so.
Old Jan 1, 2010 | 10:34 AM
therewolf's Avatar
Thread search the Silverado section. Apparently the 4l60e has a couple of common problems.
Old Jan 15, 2010 | 8:07 AM
djoker04's Avatar
These are in the Valve Body, Right? did you do it yourself (the change ) or a shop. If a shop how much did it cost you? I'm having issues with mine but my Service manual says possible clog (I don't have any codes however). Just need a heads up on how hard it would be to take out the VB.....
flewster
Jul 28, 2021 2:20 PM
abqgolfer
Aug 27, 2011 11:30 PM
mygreenihc
Aug 30, 2009 10:34 PM
remtlm
Sep 15, 2008 10:01 AM
oppelousas
Jul 25, 2007 1:46 PM
