4wd ticks
Old Nov 20, 2010 | 3:11 AM
Bearkitty's Avatar
Default 4wd ticks
When I put my truck in 4 high, it ticks only when I gradually accelerate or decelerate. 4 low doesn't tick as much, but does lightly. any ideas as to what it is?
Old Nov 20, 2010 | 2:49 PM
2wd-K5's Avatar
i take it you are talking about the jeep in your pics? i had one that ticked in 4wd, it was a halfshaft universal joint in the front end, just get underneath and check for play in them, if no play check the front driveshaft universals
Old Nov 21, 2010 | 12:04 AM
Bearkitty's Avatar
Thanks. I'll check it out.
It ticks on my 86 Chevy K10 Pickup. My Cherokee in the pic was my first car and has always been my favorite one, but it is now in a junk yard. But it still means a lot to me.
Old Nov 21, 2010 | 1:02 PM
2wd-K5's Avatar
yea those jeeps are great little units especially in snow and such, in the 86, it could be the same, have a friend walk with the truck as you go slow in 4wd and see if he can pinpoint where the sound comes from. to change the universal it is fairly simple first u take the hub apart u will need a hub tool (or a lot of time and messing around with screwdrivers) when the axleshaft is out u must remove the c-clips they are on the inside of the joint in axleshafts then put it in the vice and with either an impact socket or a pice of steel tubing you pound them out. if you have a huge bench vice you can achive the same results without the risk of damage from poundin by using a large socket on 1 side and a small one on the other to push it out using the pressure of the vice (hard to explain exactly, but a good wrench will figure out what im saying) hope this helps
Nbish84
Jul 21, 2014 7:49 PM
isaacjames24
Mar 6, 2014 5:44 PM
LWT
Jul 29, 2012 4:13 PM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
