4X4 Tire Alignment issues
Old Jan 14, 2020 | 2:06 PM
Alejandro Maldonado's Avatar
Default 4X4 Tire Alignment issues
So I purchased an all inclusive 6 inch lift kit from Rough Country, only modifications was to cut and re-weld the exhaust, after installation I take my blazer to get an alignment, and the shop can't seem to get it aligned and now it pulls to the right hard, does anybody else have that same lift kit and came across with the same issues??
Old Jan 14, 2020 | 4:27 PM
suspension lift or body lift?
if suspension lift...did it include upper control arms?
post the alignment printout
did you put new oversized wheels and tires on as well?
Old Jan 14, 2020 | 8:38 PM
too much lift. take it down to 4"
Old Jan 15, 2020 | 8:35 AM
It is a 6" suspension lift, the kit did not come with new upper control arms , and I did change tires , I have 33s AT BF Goodridge on a 15 by 12 rim, and there is no other lift out there besides this 6in , I tried looking without any luck
Old Jan 15, 2020 | 8:40 AM
Old Jan 15, 2020 | 5:40 PM
post the alignment printout...then I can see what is causing the pull. if the alignment shop could get the caster/camber in spec...you may need longer uc arms.
frankhulse
Feb 11, 2018 6:19 PM
vettekid95
1988 - 1998 (GMT400)
Dec 24, 2016 7:00 AM
acer9876
Jan 14, 2012 3:10 PM
jbo9287
16
Aug 7, 2010 2:43 PM
