5.7 Vortec sputtering
Old Apr 7, 2008 | 6:32 PM
zgcruiser's Avatar
Default 5.7 Vortec sputtering
I'll start with a little background..I did a swap in my 1976 Toyota Landcruiser with a 1996 5.7L vortec. It idles smooth but under throttle it sputters almost like a misfire..it will smooth out sometimes and then start up again. I have replaced the following: Spark Plugs, wires, fuel filters, fuel pump (was and still getting good pressure), distributor and cap, and added a Mallory HY Fire off road ignition system. And none of this has helped! Any suggestions! Let me know. Thx Ray
Old Apr 7, 2008 | 7:17 PM
Cactus's Avatar
Default RE: 5.7 Vortec sputtering
crankshaft sensor
Old Apr 9, 2008 | 5:54 PM
zgcruiser's Avatar
Thx for that I just got one and will give that a shot! Thx Again!!
Old Apr 12, 2008 | 10:08 PM
zgcruiser's Avatar
Tried that didn't work..In low range it runs ok because the higher rpm's. In high gear it is has no power just spudders and backfired.
Old Apr 13, 2008 | 5:33 PM
jkgray80's Avatar
Sounds like you have gotleaking injector(s). Put a fuel pressure gauge on it. Cycle key on & off several times-Dont start engine.
Watch gauge. Should hold steady pressure. If it drops suspect injector(s). Injectors are under upper intake.
Old Apr 20, 2008 | 8:57 PM
Cactus's Avatar
check your coil wire
Old Apr 22, 2008 | 7:01 AM
tjlandrover's Avatar
I know 98 motors, the one I did acted like that until , I got the computer reflashed by GM, BUt missing at high end, sounds like a timing issue, see theres no way to tell wheter your mil is on, what r u running carb, or the complete fuelie computer, etc....
Old Apr 24, 2008 | 8:05 AM
hquick's Avatar
Yeah....sounds like timing is off. Needs to be +/- 2deg. Only way to set it is with a scanner.
brothers4.3
11
Sep 23, 2014 8:35 AM
hugginporceilin69
Aug 1, 2009 11:08 PM
Rustybolt
Apr 28, 2009 7:43 AM
dariverrat
Jun 17, 2008 7:04 AM
96GreenMonster
May 10, 2008 8:32 PM
