Notices
67 c20 runs rough
Old July 15th, 2018, 7:11 AM
  #11
Verify that you do have the original carb. Over the years one of the previous owners may have changed it. Rochester 1 barrel carbs look the same from year to year but they do have difference on the inside.
Old July 15th, 2018, 9:34 AM
  #12
Leland drives 1967 Chevy c20's Avatar
it’s original but, I’m worried about after market carb kits, I’ve had bad luck on those with ATVs and dirt bikes. Also how much will that motor be worth once running perfect again? I’m thinking about decommissioning the truck for a while and selling the motor to buy a 350 and then put that in. But I would like to know what the engine is worth. It burns no oil and has 55,000 miles on it.
Old July 15th, 2018, 10:49 AM
  #13
It is worth whatever the person who needs it is willing to pay. Here is an example:
https://www.ebay.com/itm/CHEVROLET-1...25.m3641.l6368
Old July 15th, 2018, 11:12 AM
  #14
my engine is way nicer than that..... should I ask 750? And how will it effect value of my truck?
Old July 15th, 2018, 11:15 AM
  #15
Since you are not restoring it to original quality, you don't need a numbers matching engine. The 350 will probably increase the value in this case.
Old July 15th, 2018, 11:16 AM
  #16
sweet! Will the 350 bolt up to my 4spd?
Old July 16th, 2018, 7:12 AM
  #17
In the 60's everything matched each other. The only thing that might be different is the flywheel. It might take a different size, not sure about that.
Old July 16th, 2018, 11:35 AM
  #18
sweet! Know anybody who wants a 67 292 with 65000 original miles? It will have a fully rebuilt carb!
Old July 19th, 2018, 2:55 AM
  #19
oilcanhenry's Avatar
Might want to make real sure that your transmission will bolt up to a 350 cubic inch motor. If I recall correctly, the only V8 motor that was available on a 1967 C-20 was the 327 cubic inch engine. That said, I believe the 350 should bolt up fine.
The 350 didn't really replace the 327 to any large extent until 1970 or so. And dont put a post-1972 350 motor in your C-20. After that date, most car manufacturers dropped the compression ratio's on most engines to adapt to the new "smog" laws.
The horsepower reduction due to the low-compression engines was very noticable in 1973 to 1985 motors, back in the day.
You should have a 9.5 to 10 to 1 ratio compression engine. You could go higher then that, but if you do, you'll need to use plus or premium gasoline, unless you retard the ignition timing back, which will yield less HP and more fuel consumption.
Old July 19th, 2018, 7:38 AM
  #20
Thanks for the info, my camshaft, carburetor, and heads and intake that I’m picking should make 435 horse.
