7-pin connector surge brake question
Old Mar 15, 2026 | 8:57 PM
jeff.mccracken's Avatar
Default 7-pin connector surge brake question
I tow a boat with my 2023 1500 Z71 Silverado LTZ 4-door crew cab. My boat trailer has a Dexter (UFP style) surge actuator to activate the trailer brake when the truck is slowing. The Dexter actuator also has a solenoid that uses 12.5 VDC from “backup” feature from the bumper mounted 7-pin trailer receptacle. According to all the literature I’ve read, the center pin on the 7-pin connector supplies voltage for the surge brake actuator when in reverse (12+ VDC)… i.e. when pulling my trailer, no voltage is needed but when I backup, the truck supplies 12.5VDC to the center pin. My issue is that this truck supplies a constant 12.5 VDC to the center pin rendering my surge brake useless. A factory option in this 2023 truck is it has “Trailer brake controller, integrated” installed.
Question: Is it standard to have 12.5VDC to the backup center pin on the 7-pin connector?
Question: What do I need to do to get the correct surge brake voltage to the center pin?
Last edited by jeff.mccracken; Mar 15, 2026 at 8:58 PM. Reason: I'm a new member... hope this is the correct place for this post..
Old Mar 15, 2026 | 9:44 PM
JJL's Avatar
JJL
I seriously don't think it is supposed to have voltage until it is put in reverse. I would call the dealer or get a good schematic of your exterior lighting.
Old Mar 23, 2026 | 7:26 AM
Thanks for the input. I did go by the dealership last week and setup an appointment for Thursday, 3/26/2026.
Old Mar 23, 2026 | 8:23 PM
JJL's Avatar
JJL
Please report back with your findings!
Old Apr 14, 2026 | 12:34 PM
The truck appears to be fixed... or at least the truck portion appears good. After initial evaluation, the trailer brake control module took 2 weeks to arrive and 1 day to install. During the initial pull, the trailer did well. The surge brake worked correctly and the backup brakes disengaged correctly. But over time the trailer brakes developed a small leak. Now it's time to repair the surge brakes on the boat trailer... yet again!!! I guess that's what happens with older trailers.
eoddewey
2019+ Silverado (GMT-T1)
Nov 3, 2024 5:01 AM
kennyb04
Feb 24, 2022 12:54 PM
humnbass
May 29, 2015 10:39 PM
leevil
Mar 19, 2014 6:44 AM
kalle1066
Sep 20, 2007 10:29 AM
