71 454 a dog !!! Any help would be great
Old Aug 13, 2020 | 5:56 AM
Dave19054's Avatar
Default 71 454 a dog !!! Any help would be great
71 corvettt 454 wide ratio Muncie 4 speed
edlebrock Rpm Air Gap intake
quick fuel 750 Dp mechanical secondary
Decked 9:1 compression
Bored 60 over
Rear gear 3:36
comp roller cam info:
Cam Style:Hydraulic roller tappetBasic Operating RPM Range:1,700-5,500
Intake Duration at 050 inch Lift:227
Exhaust Duration at 050 inch Lift:241
Duration at 050 inch Lift:227 int./241 exh.
Advertised Intake Duration:283
Advertised Exhaust Duration:303
Advertised Duration:283 int./303 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.547 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.530 in.
Valve Lift with Factory Rocker Arm Ratio:0.547 int./0.530 exh.
Lobe Separation (degrees):107
Grind Number:283THR7
Lifters Included:Yes
Lifter Style:Hydraulic roller
Timing Chain Styleouble roller
Any info would be great on why it is such a dog !!! It’s like driving a stock 350!!!! Possibly rear gear ??
Old Aug 13, 2020 | 9:51 AM
Little Bear's Avatar
I'd say the wide ratio 4 speed and the rear gears, with what it has it was meant to go fast not quick.
caleb22
Aug 29, 2018 11:13 AM
jdl1990
Jan 10, 2015 7:37 AM
ernie55xx
May 14, 2011 8:48 PM
