71' cheyenne pu starting woes
Old Feb 26, 2006 | 2:18 PM
fredtz's Avatar
Default 71' cheyenne pu starting woes
Help!!! I have a 71' pu truck will not start on its own. It has almost new battery,fully charged,new points and condenser,new cap and rotor,new coil,new s-plugs and wires,bench tested starter. It will however,start when jump started with cables, also when starter soleniod is bypassed using the old "screw driver technic". Oh, I almost forgot a new ignition switch and battery terminals are tight at battery and at soleniod connections. When I attemp to start it with ignition key it cranks over,but it sounds like its stressing. It does not have the strong clear cranking sound it makes when I bypass the solenoid. Please help I'm STRESSING.......
Old Feb 28, 2006 | 11:05 PM
blankfixation's Avatar
Default RE: 71' cheyenne pu starting woes
this may seem a little bit dumb but make sure the postive cable has a good connection at the battery and at the starter.
frnch
Oct 26, 2006 8:19 AM
ChevyMechaniac
Sep 12, 2006 2:38 PM
Andrew_350
Sep 10, 2006 12:03 PM
ShadowDrake
Aug 5, 2006 3:40 PM
Soulcrusher
Jan 24, 2006 10:17 PM
