79 K10 lost all power
Old Jul 22, 2018 | 5:48 PM
Old 79 stepside's Avatar
Default 79 K10 lost all power
I have a 79 Chevy K10 pickup and while driving down the interstate the engine lost all power. Still had power to dash and starter just would not fire. No fuse-able links as I rewired with Painless re-wire kit over 6 years ago.
My coil is built in the distributor HEI system (one wire to BAT, 3 wires from base of distributor to cap. (assume I have an intermittent coil or distributor issue)??
After it cooled down for 30 minutes and checked all wires it fired back up and ran fine. Which was good I got home but bad in that I cannot test the failure.
Any thoughts would be helpful.
Thanks
Old Jul 24, 2018 | 7:14 AM
oilcanhenry's Avatar
Thanks
Never liked the HEI coil design. Something got too hot, when it cooled down, you had power. I'd toss the cap/coil if it happens again.
Old Jul 24, 2018 | 1:39 PM
My thoughts as well, just ordered a Proform distributor tune up kit to upgrade Cap, coil and control module. If that does not fix it I would guess it is a short in the power supply to the coil.
Old Jul 24, 2018 | 2:02 PM
kevinkpk's Avatar
Is the power to the coil from a resistor switched from the stater solenoid?
Old Jul 24, 2018 | 3:32 PM
Nope goes direct from the coil to the fuse panel and connects to the BAT terminal no tach so thats the only wire coming in.
