88 caprice shifting problems
well the problem im having with it is, when i go to start it, it revs real high and doesnt come down. so when i put it in gear it shifts real hard into drive or reverse and wont come out of first tell real high rpms. but when it warms up, it shifts good
sounds like a few things. possibly a vacuum leak. idle air control valve. bein an 88, is it still carb or throttle body fuel injection? if carb, could be choke issue. doesn't sound like it's tranny tho. i'd check all the vacuum hoses, then pull the idle air control valve off and clean it well. double check all wiring connectors too.
yea its throttle body, thats what my dad thinks it is, is the idel air control valve. I just started and drove it home and it ideled and drove like a champ. My brother has been helping me with it and said he couldnt find any vacum leaks. He did spray crab cleaner towards the egr valve and the car almost shut off, not sure if thats normal or not.
thanks for the fast reply and help
Justin96ss
Jan 30, 2015 4:42 PM
