91 454 egr valve removal help
I have a question about removing the egr valve on a 91 chevy 454 in a one ton dually. I need to remove it to replace the valve cover gasket. my problem is this: a 13mm is too big, a 12mm too small. a 1/2 inch is to big, a 7/16 inch is too small. my question is what do you get the nuts off with? I really don't want to pull the intake over a valve cover gasket. do I need a special tool? any help is appreciated and gratefully accepted. thank you
1991 chevy Silverado c3500 extended cab dually
454 auto rwd
454 auto rwd
454 auto rwd
454 auto rwd
I'd either chisel it off, or buy a real cheap wrench at Harbor Freight, and grind it down until it fit the nut. That is if it doesn't strip- out, as those tools are made in China and not worth much. If it works great, If not you are not out much $$$.
