92 chevy lumina 3.1L v6......
Old Mar 12, 2011 | 5:04 PM
chevguy86's Avatar
Default 92 chevy lumina 3.1L v6......
i need help i have a 92 chevy lumina and im trying to change out the lock cylinder. it has a steel steering column and i cant seem to get to it is there a special tool or way to get to it ? please help thanks
Old Mar 12, 2011 | 10:09 PM
RacerX's Avatar
you have to use a pick to get the center retaining ring up, after you get the steering wheel off and then once removed the lock stop comes right out. Then you turn the lock cylinder a little to line the pins up and it slides right out
Old Mar 14, 2011 | 10:28 AM
chevguy86's Avatar
i got the steering wheel off and the turn signal switch now im stuck i still cant get to the lock cylinder ? i dont see any more screws or bolts ?
Old Mar 14, 2011 | 8:11 PM
RacerX's Avatar
Nope. There are like tabs in there you have to press and the lock cylinder comes out. I cant remember but if you have the new cylinder look for the for the tabs. The key has tobe in the cylinder I think to make it easier.
Old Mar 15, 2011 | 2:40 PM
chevguy86's Avatar
turns out i didn't have to do that there was actually a screw holding the lock cylinder in place in a very difficult to get to place but i managed to get it out and replace the lock cylinder with just the steering wheel off. thanks for your help maby this will help someone in same situation.
MagicElectric
Feb 27, 2007 3:42 PM
bjthebetsig
Aug 26, 2006 12:24 PM
yakima
Aug 13, 2006 12:20 AM
yakima
Aug 13, 2006 12:16 AM
blackcat86
Jul 25, 2006 2:15 AM
