92 chevy truck
Old Oct 23, 2006 | 5:40 PM
hebossy's Avatar
Default 92 chevy truck
I have a 92 chevy truck with 4.3 v6, automatic trans.
I have no voltage at the throttle body injectors. It has a new computer,electronic module,and pickup coil.
Where do i go from here
Thanks Buster but i also put in a ignition switch after listing here. Anybody got a chevrolet service manual for this vehicle am willing to buy it. Thanks Ricky
Old Oct 23, 2006 | 7:33 PM
buster's Avatar
Default RE: 92 chevy truck
Ignition switch ???
Old Nov 11, 2006 | 11:33 PM
chevymandan's Avatar
electronic module ??? meaning ignition module ????
Old Nov 12, 2006 | 1:58 AM
70mopar's Avatar
have u traced the wires (visually & for continuity) from the computer out to the injectors? i mean physically looking @ the wires each and every inch through-out the harness. i've seen the ground side of the injectors wiring harness corrode @ a splice about 6-10 inches back from the plug.
Old Nov 15, 2006 | 4:06 PM
hebossy's Avatar
Thanks mopar
Tryed what you said and found that i had no 12 volts to the injecters. now to trace the wires through the dash
Old Nov 15, 2006 | 9:39 PM
70mopar's Avatar
when u r tracing the wires to the computer, u'll find the same red and blue wires run into the same plug. the wires r 12 gauge (if i remember correctly). while u r checking the voltage for the injector's, remember that the injector's "fire" by switching the ground, so if u haven't checked this make sure u do (this is where i've seen the most problems occur) see my post above.
dragonmaster
Sep 29, 2009 2:30 PM
chevy for a penney
Nov 19, 2008 1:36 PM
m0n0x!de
May 14, 2008 1:46 PM
chevyman1978
May 1, 2008 6:41 AM
