96 tahoe charcoal canister help
Old Oct 24, 2018 | 11:50 PM
Nick Stevens's Avatar
Default 96 tahoe charcoal canister help
I have a 96 tahoe with the 5.7 and I got a code for the charcoal canister. I cant find a replacement in my town, only a filter. If I can buy a filter I'm assuming I can open the canister correct? Is there anyone who has done this that may have any helpful info you could share with me? Thank you for your time in advance.
Old Oct 26, 2018 | 8:42 PM
oilcanhenry's Avatar
Its not servicable. If its not working properly, you have to replace it. What OBD II code do you have?
Old Oct 26, 2018 | 8:46 PM
Default Code
Thank you for the reply. The code tour asking about is P0441
Old Oct 27, 2018 | 12:21 PM
Might not be the carb cannister. Here is a list that can pull a P0441 code:
  • Missing fuel cap
  • Stuck open or closed purge valve
  • Defective or damaged fuel cap
  • Distorted, damaged or cracked Fuel Tank Filler Neck
  • Torn or punctured Evaporative system hose(s)
  • Defective Fuel Tank Sending Unit gasket or seal
  • Split or damaged Carbon Canister
  • Defective Evaporative Vent Valve
  • Defective or damaged fuel tank
I hope this helps you solve your issue.
Old Oct 27, 2018 | 12:26 PM
  • Missing fuel cap
thank you
