99 Silverado 1500 ABS and Brake lights
Old Mar 27, 2017 | 7:59 AM
Justin Weber's Avatar
Default 99 Silverado 1500 ABS and Brake lights
A little while back the ABS and Brake lights lit up on the dash. Truck has no issue with braking that I can tell. The pedal still has good pressure. The brake fluid is still at a good level. Sometimes the lights will not come on until I'm driving and I hit a good bump. Brake pads still have good life to them. Not sure what to do from here. Any help would be appreciated.
Old Mar 27, 2017 | 10:58 AM
My 99 did that also. It was recommended to clean the sensors. I did that with no help. I replaced the sensors with no help. I didn't want to replace the ABS unit because of cost, so I just lived with it. Mine only did it occasionally, it wasn't that bad.
