ABS, Traction and code P069E
So today as I went to work I went across rail road tracks and I got a service engine , service stability (sp?) service traction. My car drove just fine. After work the lights were still on until I shifted it into drive and they went off. Than I hit a small bump on the free way about 10 mins later and it popped on. After I got home I turned it off and decided to go to autozone to see if they could run a test... as I drove there was no lights until I hit a bump. I got the test done and it came up with code P069E fuel pump which I was surprise. There is no check engine light. I turned of the traction and drove for a while the lights as of now had not returned but I don’t think that be the end... as you guys may guess I’m not real car smart and any advice in simple terms be great... I don’t have a lot of cash to pay for expensive parts... also how long can I drive on something like this? Because if I could hold off until taxes that be great but I don’t want to make the problem worse... thank you all in advance Deb
