Notices
AC blows cold till 90 degree setting
Old April 21st, 2015, 3:10 PM
Aavronle@gmail.com's Avatar
Default AC blows cold till 90 degree setting
The AC blows cold air on every setting but 90. Below 90 you get the same cold temp regardless of setting. At 90 it blows hot air . . . thoughts?
Old April 21st, 2015, 7:51 PM
jamespsj's Avatar
What's your vehicle and model? I haven't encountered this issue, it's usually the a/c not working or blowing hot air when turned on. They say the common cause for hot air blowing is loss of refrigerant. But in your case, it could either be an obstruction inside the refrigerant circuit that prevents refrigerant from circulating inside the A/C system, or a blend air door stuck in the HEAT position of the HVAC unit preventing air from flowing through the A/C evaporator. But like most people here, i'm just guessing. Have a professional technician take a look at it for proper diagnosis. Hope it gets fixed.
Old April 21st, 2015, 9:52 PM
Rednucleus's Avatar
Maybe I'm a dork but shouldn't the 90 setting be calling for heat? So are you saying at lower settings - say 65-75 - it's blowing cold vs a more blended setting?
Old April 21st, 2015, 10:07 PM
sledge.impy's Avatar
Yeah - this makes no sense.
in2pro
July 14th, 2014 9:31 PM
Buckmaster73
June 28th, 2012 9:09 PM
newmonte06
June 7th, 2010 8:30 PM
Guvner2
Site Feedback
March 28th, 2009 7:56 PM
david_351
December 26th, 2007 5:18 PM
Quick Reply: AC blows cold till 90 degree setting
