AC compressor cycles on and off 1987 even after charging
Old Oct 21, 2017 | 10:25 PM
sqrbdy's Avatar
Default AC compressor cycles on and off 1987 even after charging
AC Compressor cycles on and off on 1987 c-10 I just bought. Charged with UV but no visible leaks and still cycling on and off. Next step?
Old Oct 22, 2017 | 1:22 AM
Rednucleus's Avatar
Sorry to be dense, but isn't it supposed to cycle? Is it doing it at an incorrect rate?
BTW welcome! You will find a lot smarter folks here than me!
Old Oct 22, 2017 | 5:55 AM
oilcanhenry's Avatar
Some A/C units cycle and some dont. All that really matters is that the cool air temp at the outlets is between 38 and 45 degrees F or so when driving.
Old Oct 22, 2017 | 10:26 AM
if the compressor short cycles, on and off every 15 seconds...the system probably has a low charge. have the system recovered and if the recovered amount it low...it either wasn't filled to the proper level or you have a leak.
