AC compressor wont kick on
Old Oct 6, 2006 | 4:28 PM
mj58595's Avatar
Default AC compressor wont kick on
I have a 1993 gmc yukon. The a/c has been converted to R-134. Lately the compressor will work sometimes and sometimes not. I figured that it was low on freon so i bought a refill kit from Walmart. When i hooked up the pressure guage on the low side, the pressure is real high (100 psi). I am not sure now what is going on. If the pressure is too high, will the compressor not kick on? If i bybass the low pressure switch, the compressor will kick on and the pressure will start to drop, but only to about 50 PSI. I figure that this is probably the source of the problem. Does anyone know why pressure would be building up so high on the low side???
Old Oct 7, 2006 | 1:03 PM
andregg1's Avatar
Default RE: AC compressor wont kick on
Hi
The reasons that I know are: the expansion valve stuck open.
Refrigerant overcharged
Air in the system
cooling fan faulty.
Symptoms: The discharge air is warm
the evaporator is sweating or frosting
Andre.
magoecke
Dec 21, 2013 5:31 PM
ekoms
May 30, 2010 10:36 AM
Silvy1500
Jul 1, 2007 7:04 AM
layne
Aug 21, 2006 5:14 PM
biggred35
Camaro
Dec 7, 2005 9:17 PM
