ac issues
ac issues
I have an 03 silverado 5.3l v8. Ac problems. Last year, my compressor (I'm assuming) would cause my ac tensioner to knock and broke 2 belts. Assuming bad compressor, I left the belt of and dealt with the heat. This year, I tried again and put a new belt on. Knocking was gone. Freon was low and I unscrewed high side valve and it flew off. Realized I had a leak at the high side valve. I then changed the valve, orifice, and accumulator. Evacuated system with pump. System helda vacuum. Refilled freon (only one can put it in the green which according to autozone is way less than what the system should hold). Blew cold at idle. As soon as I drove off, it stopped blowing cold, only slightly cool. Clutch stays on as it should. The old orifice looked like it had metal dust on it. Could it be sensor or compressor? I have the dual manual climate controls inside. Also, my truck seems to be getting low on coolant lately. Not sure if that could be related. Please help
samsaridinc1500
January 10th, 2014 9:12 PM
