ac wiring
#11
RE: ac wiring/clutch
The fornt hub is a press fit. There is a hub installer, but it uses the threads on that shaft. Or you can use a nut on the shaft to press it on. The only other way to put the hub on without using the threads, is to put it on with a hammer. But you run the risk of damaging the internal components by smashing the end of the shaft
Shaun_95
November 23rd, 2009 9:56 AM
