Add Drivers side power window 00' Prizm
I have a 2000 Chevy Prizm with roll up windows and I was wondering if it was possible to add a power window to the drivers side
Anything is possible if you want it bad enough. You will need the power window assembly that would be there if it had it from the factory. You will need to install that and also hook up a switch and run 12 volts to the inside of the door. Not as easy as it sounds, but also not that difficult.
chevy20006
July 19th, 2011 12:49 PM
