Add Drivers side power window 00' Prizm
Old Jul 25, 2012 | 12:52 AM
Fiosman's Avatar
Default Add Drivers side power window 00' Prizm
I have a 2000 Chevy Prizm with roll up windows and I was wondering if it was possible to add a power window to the drivers side
Old Jul 25, 2012 | 11:46 AM
Anything is possible if you want it bad enough. You will need the power window assembly that would be there if it had it from the factory. You will need to install that and also hook up a switch and run 12 volts to the inside of the door. Not as easy as it sounds, but also not that difficult.
Old Jul 25, 2012 | 11:03 PM
Fiosman's Avatar
Im still debating, thanks for the reply
dogman1313
Apr 2, 2012 8:47 PM
chevy20006
Jul 19, 2011 12:49 PM
bans25
Uplander
Jul 15, 2011 7:40 AM
ladydichaa
Jun 29, 2010 11:49 AM
