Advice needed for engine knock in 5.3
Old Jul 31, 2014 | 12:34 PM
Mark F's Avatar
Default Advice needed for engine knock in 5.3
I had a 5.3 crate motor in my 01 sub installed last year. When it is hot outside and the engine is hot it knocks (pre iginition) under light throttle but not at WOT. I have had the Tech2 update done which helped but the mechanic says nothing wrong with motor.
Any ideas?
Old Jul 31, 2014 | 2:52 PM
Its a shot in the dark but have you tried using a higher octane fuel to see if that does anything... there is probably more going on but its an easy enough thing to try to see if it changes..
MissionValley
Apr 2, 2014 1:55 PM
Stech
Mar 16, 2010 12:22 PM
brudel1
Nov 20, 2006 4:17 PM
remembermorrison
Jun 20, 2006 10:48 PM
