Alternator and Battery Problems
Old Sep 19, 2016 | 3:45 PM
asteroid galaxy's Avatar
Default Alternator and Battery Problems
So, I have had a frustrating problem for the last couple of years. In summary, it's an 87 Monte Carlo SS, 383 stroker, with a 105 amp alternator. I'll get a brand new Optima battery, the car will start once or twice and the battery is dead/fried and has to be replaced under warranty. So the car keeps eating batteries and I have replaced the alternator three times now. I'm unsure how to troubleshoot this if anyone has some guides, flow charts, or ideas? Thank you in advance.
Old Sep 19, 2016 | 4:56 PM
kevinkpk's Avatar
Try this, after the car is started, pull the + cable off the battery, does it die?
Old Sep 25, 2016 | 11:29 PM
SWHouston's Avatar
Check the cranking amps of your Starter. (replace if excessive)
Size Battery for that demand.
Check Cables and increase size if draw is large (600+ amps)
Check clean ALL connections.
Double strap grounds on Engine. (battery ground/frame straps)
